which 42"+ LCD...?
28 Nov 2003
Manchester, UK
Looking for a possible 42"/46" LCD, which one would you choose for upto around £2000?
That price must include a stand also.
Leaning towards Samsung at the moment but cant decide on which model.
We need a budget!
If money is unlimited, go for Sony 46X2000, otherwise Sony 40X2000, or 40W2000.
Raider said:
We need a budget!
I wish money was unlimited :p
As stated though, £2000-ish tops with stand. Preferably ~46" and high res.
If by high-res you mean 1080p, then the 40W2000 is the only thing inside your price range. You should be able to get it for around £1700.
The only 46" screen for under £2000 will be 720p, not 1080p.
chaparral said:
The higher range sony KDL-40X2000 & KDL-46X2000 are stunning displays but are a little over your £2000 budget.
40x2000 can be had for £1937.90 including a table top stand if you shop around, but that won't include an extended warrenty.
Excellent TV and I'll be ordering mine in the next few weeks.
