which 4k tv is best? pls help
The LG is the better buy the toshiba is just a rebranded vestel tv while its perfectly adequate i would not chose one over the LG.
If it's just out of those two you've listed then the LG gets my vote.
If your open to other suggestions, what's your budget & what are you looking for in a TV?
Hi all,
thanks for the replies. Had a few LG tvs now and had a few problems with them. One of the problems with the LG is the sound and the other is that the hdmi ports went inside the tv.
Not really a choice if you'd rather avoid LG. Leaves you with the Toshiba, which is a rebranded TV.
If you've got a Richer Sounds store in your area, they have a 40" Samsung UE40MU6120 for £350, in store only. If you don't, then John Lewis has the same TV for £380.
Might be the best alternative to LG in that category.
