Which 570s for sli?
Exe
Exe
17 Nov 2011
I was looking into getting the gigabyte 570s due to the fans would be cooler than stock and less noise im guessing. ALso all of the reviews seem positive about this card
Do you have a case with good airflow? a reference design GTX570 cooler dumps all the heat out of the rear, where as the Gigabyte leaves it mostly in the case.
What about your PSU, is that good and 750W+?
well im planning on staying as stock for now then going for a 1000 - 1200w in the future for maybe 3 way or so
