which 5770?
2 Mar 2007
Leeds, UK
Hi all,
I'm in the market for a 5770, but which is the one to go for? I would like one with voltage tweak, which ones have this feature?
Cheers
sweet!
Thanks guys. I was aware of the asus one, but not the sapphire. I think I can get hold of a sapphire today, so it's off to the shops I think!
Cheers guys!
Yeah, wouldn't bother paying £20-30 more just for vapor-x. If your case has decent airflow there's no need and if it doesn't buy 2 or 3 more 120mm fans for your case with that £20-30 :)
Thanks for the advice guys.
I managed to pick up an Asus Cu-core, which was sold as an own brand offering, so cheaper than usual too. Bargain!
Looking forward to clocking it, and possibly crossfiring at some point.
Dont get the sapphires. They have shortened the PCB even on the Vapor X and they no longer support any kind of voltage tweaking in software.
