- 29 Aug 2010
- Cornwall
With any luck I'll soon be fitting a full cover waterblock to my 5870. Yay!
The thing is, the more I think about it, the more I think it might be harder than I first thought. How hard is it to fit a waterblock to a 5870? Remember this will be my first time.
How easy/hard is it to re-attach the stock cooler at a later date? Will I need more thermal pads to do that?
Got any tips?
And now to the thread title, which block is best?
The 2 I'm considering are the XSPC Razor 5870 and the EK FC5870 Plexi. The EK one looks better imo because of it's plexi top. Although I will only be using Bi-Distilled Water and a Kill-Coil, in a case with no side window. Still might be handy to be able to see inside. But the EK block is £10 more.
Also, is it worth getting an EK 5870 RAM backplate? Costs ~£12, is it worth it? Can it be used with the XSPC block too or only the EK block?
Thanks in advance.
Got any tips?
Thanks in advance.
I'm toying with the idea of wasting 24 quid on a pair myself.
