I have read most memory defaults to 5,5,5,15 instead of the specced 4,4,4,12 it is capable of (micron) and some memory defaults to 667mhz instead of the specced 800mhz for safety reasons (geil).
Can anyone tell me of any 6400 DDR2 that has the SPD programmed to run at 800mhz 5,5,5,15 or 800mhz 4,4,4,12. My motherboard does not have any ram timing adjustment but it does support DDR2 6400 and I need to get new ram. But obviously only whatever is programmed into the SPD will run. I have been recommended the Crucial Ballistix 6400C4 2gig kit as being compatible. Just wondering if this is the same micron stuff as the Team Extreme 6400.
Regarding the benefits of DDR2 6400 - as the PC is not overclockable at the moment and the cpu is running at 266mhz would there be any benefit to running the memory out of synch at 400mhz, besides the advantage the video card might have from reading from faster memory directly ? It seems like wasted bandwidth and I know some people say not running at 1:1 and using a divider (which would be the case here as the cpu would automatically use one to keep at 266mhz) is always a negative although I never found in the past.
