I plan to get a 780 over the weekend.
I don't like spending more then I have to, I see they start at £389.
Which is best to get considering it'll have a water block on it from the word go?
A lot of the price increases I am guessing are due to better coolers but that doesn't matter to me. However I see the Asus has a better power design for better overclocking(?) but has a lower clock then the Inno3D.
I don't plan to spend over £429 if I can help it, is there one that is better then any others & if you were in my position which one would you go for and why? I do plan to overclock it, but not within inches of it's life.
2 Questions also:
My water block is a standard VGA block, it fits "most cards". Does it fit the 780?
It's a VGA block only, on my 670s the ram doesn't need cooling. Does the 780 ram need cooling?
2 Questions also:
