- 1 Aug 2009
'The ice Q probably has slightly better cooling'.
Only in that it blows the hot air out. Nothing between the temps on these cards would suggest to me that the WF3 has the better cooler as it manages great temps despite heat being dumped in the case, but I suspect good case cooling would be essential.![]()
ICE Q has UBER COOLING...
Idle Temps is not what you should be going off lol My card sits at 25c at times. Its the load temp that matters, gaming my max temp is around 60-70c Over clock of 1100/1500 @1.131v
Sorry ViRuS2k but thats no better than my WF3.![]()
Your card ? im running crossfire with 2x of them and the gap between them is like half a fingernail lol, i would say its very good.
XFX HD 7950 Double D
You only have 1 card ?
And you have two running idle which blow the hot air out of the case.![]()
What about the noise difference between the cards? One impeller against three fans that dont have to work as hard?
