Which 80mm fan? Also Cable sleeving kitS!
Not too bothered about noise as I have the seasonic 600w so the fan can make up for that
Erm, are the Vantec Tornado's any good? Want to pull a lot of air thanks
ALSO :
http://www.overclockers.co.uk/acatalog/Online_Catalogue_Cable_Kits___Others_36.html
Should I GO for the Vantec Cable sleeving kit? Should I buy two as I dont fancy taking of any molex connectors
So, I will get twice as many large size sleeves.
Thanks guys
ALSO :
So, I will get twice as many large size sleeves.Thanks guys
Oh and they look good if you've got a side panel
