Howdie
I have just setup an HTPC with the silerstone LC16M case but the fans that come with it are too noisey on 12v and dont push enough air on 7v.
Can anyone recommend some replacement 80mm fans that would push a decent amount of air at low noise levels - price isnt really an problem as i only need 2 of them.
Also looking for a silent psu for the same system - doesnt need to be very powerful (400w should be plenty) modular would be a plus but noise levels are my main concern - have been thinking either the enermax liberty 400w or the Tagan modular 400w but are there any quieter but not a lot more expensive options ?
Thanks
Thanks
