Which 9070Xt are you going for?
16 Oct 2018
So cards out soon, I'm deciding between a Powercolor Red Devil or the Asus Tuf. Going from a 2070 super so will be a nice upgrade.
Any advice or opinions welcomed.
Cheers
Liking the look of the Gigabyte Aorus Radeon RX 9070 XT Elite , let's see what it's priced at and might be tempted
Depends on the price. Also it's been ages since I bought a GPU. I want one that switches the fans off when it's not under load. I don't know if that's a standard feature these days.
Reviews are minutes away. I want to see how much of a difference the 304w is to the 340w. Then just general cooler performance. If there's not much in it, I'll just go for one of the cheaper ones.
Im not, ive got a 3090 and while i fully believe the 9070 will match the 5070/ti. Neither are enough of an upgrade for real frames over what ive got
Been flitting back and forth between the pulse and the red devil. I hope reviewers are able to test some of the higher power models to see if its worth the price premium. Though currently leaning towards the pulse as I only have 2 matching power extension cables :P
I did want the Taichi, but I'm not so sure at that price. I might just go for the steel legend and try to give it a little OC myself.
