Getting a bit tired of the ugly orange fans on my T/take soprano so I'm planning on changing them. Sure whoever designed the soprano could only see in black and white! Already sorted for which 120mm's to go for but as for the side fan I'm a bit unsure. Can anyone recommend a good 90mm preferably in clear or black? Also will a 92mm fit on the soprano's fittings for the side fan or do the extra 2mm of fan require a bigger fitting?
Thanks
Thanks
