Which 92mm fan
26 Nov 2004
Carshalton, Surrey
Looking at getting a 92mm to go on my hr-03/r600 which of these would be best and is quiet. I'm not always sure i believe the db(a) ratings.
Akasa AK-184-L2B Amber Ultra Quiet 92mm Fan - 3 pin
Sharkoon Silent Eagle 1500 92mm Fan - 3/4 Pin
Xilence XPF92R Red Wing 92mm Quiet Fan
Zalman ZM-F2 92mm Silent Case Fan - 3 Pin
Leaning towards the xilence as have heard good things about it for the money.
My main aim is to get decent cooling on my 2900xt but quieter than the hoover i have at the moment.
I have the Akasa amber 92mm strapped onto my 6800le copper heatsink. Reduced temps by a minimum of 15 degrees and is very quiet inside the case (You don't really hear it, even with the 120mm's turned right down). The 120mm versions are not exactly quiet though. They are only about £3.50 each or something like that as well :)
Matthew
