My basket at Overclockers UK:
- 1 x EVGA GeForce GTX 980Ti Superclocked+ ACX 2.0+ 6144MB GDDR5 PCI-Express Graphics Card (06G-P4-4995-KR= £529.99
- 1 x MSI GeForce GTX 980Ti Gaming 6144MB GDDR5 PCI-Express Graphics Card (GTX 980 Ti Gaming 6G)= £539.99
- 1 x Gigabyte GeForce GTX 980Ti G1 Gaming 6144MB GDDR5 PCI-Express Graphics Card= £539.99
Total: £1,621.07
(includes shipping: £11.10)
Those 3 are all epic and come with substantial coolers.
Gigabyte has the best support followed by EVGA, the MSI well I haven't seen the rep since the fan oil fiasco.
Ti in SLi can be hot and it can be noisy. Prepare thyself
If I were to do it again I'd go with at *least* 1 Hybrid card for the top one to control the heat/noise better, both if possible
If you're buying from scratch then get 2 Hybrids for sure
Was thinking the hybrid would be another good choice especially cooling wise but how well do they overclock compared to the 3 above?
Generally just as well, but the best thing is the extra cooling capability helps it to maintain the boost clocks too![]()
I'll assume that if i do end up getting 2 Hybrids the radiator and fan should be mounted at the front of the case as intake?
Total: £1,621.07
none of the above
sli = refrence with refrence cooler or hybrid or watercooling.
None? none at all?
What makes you say that as people have been using these custom cooled cards in SLI just fine before any Hybrid models came onto the market.
As long as the case is ok (which it should be if spending £1000 on gfx cards) then there will not be any issue using any of those three.
There's definitely people out there who have used these open air cards in SLI, but how many will honestly say the heat/noise output is not a problem. I don't think it's necessarily best to recommend those cards in SLI, unless you've had first hand experience of doubling up the heat in your case and can honestly list the pros and cons. Hybrid or reference is the safest bet in SLI imo. One Hybrid coupled with an aftermarket card isn't the worst shout either.
