Which 980Ti
13 Feb 2010
Bournemouth
Hi all.
I was just wondering what the best 980ti card was for water cooling, with a custom loop and block, not one of the all in one cards.
Cheers
If you are doing a custom loop, all the cards are pretty much the same unless you are willing to get some premium ones. Just make sure that you buy the correct water block for the card.
