Which aftermarket Cooler
16 Feb 2012
HI,
I Have a 560ti Zotac gpu with dual pci, I have been told it is a reference card due to it having a longer board so I will be able to fit a aftermarket cooler on it def the gelid icy but ive also looked at the Accelero Twin Turbo 2 will this fit aswell.
If so which should i go for
Thanks everybody
I'd go for the Arctic Accelero TT2. One reason is that the fans are directly connectable to the graphics card and use its PWM function so you can retain temperature control, whereas with the Gelid you'd have to plug it in to your power supply and settle at one speed as far as I know anyway.
Plus the Black and White colours of the Arctic looks really nice.
If i'm totally honest I wouldn't bother changing the cooler unless the stock one is defective or you're doing some serious overclocking as the change in temps is so very little.
Maybe but the change in noise can be quite dramatic.
