Which AGP graphics card for £200 help please?
12 Nov 2002
Sheffield
Hi...i have a budget of £200 to spend on a new graphics card,my Ati 9800 pro is getting long in the tooth and im struggling with the new games.i need a new AGP graphics card and dont know which to go for as its bin a long while as you can tell,since ive upgraded.....ALL SUGGESTIONS WELCOMED. :confused:
wait a few more weeks dude and the 7800gs will come out which will be the fastest agp card ever released and possibly the last. Gibbo has stated that it will be around 200-250 quid. if u cant wait i would get the most expensive ati agp card that u can afford on overclockers.co.uk
hope this helps dude.
edit: http://forums.overclockers.co.uk/showthread.php?t=17525037
you might wanna check out that thread as well :)
CHEERS M8.....Will do just that. ;)
