Which AIO should I get?
Can
Can
23 Sep 2020
Hey everyone, I want an AIO for my Ryzen 5 3600 for looks and silence so please don't suggest an air cooler. I could either get a Barrow LTCPR 360mm AIO or a Silverstone PF240. The Barrow is only 10 USD more expensive and I want it more because it is 360mm. However, I am not sure of the brand Barrow and its quality. Can somone guide me? Thanks.
My H100i is the loudest thing in my computer even on the quiet preset. Anything with fans makes noise.
Let me suggest a Noctua NH-D15 :D
If you're looking at an AIO for 'silence' you might want to reconsider, you'll often be generating more noise due to having a pump as well as fans.
If it's purely for the aesthetic? I'd second the Arctic Freezer II as unlike most AiO's it's actually a decent quality product.
No RGB in the Arctic though. I am getting it mostly for aesthetics. I mean I am fine with some noise but my current air cooler makes extreme amount of noise I think it is faulty or something it is a Snowman M-T6 however the cooling is good.
You `could`swap out the supplied fans for RGB if you want Bling
do you look at your case or your monitor?
At the start of the year I bought a Deep Cool Castle 240 RGB V2 and its very aesthetically pleasing. Its good for its price also available from multiple retailers and lastly its pretty quiet...your never going to get silent from a cooler. Also noise can depend a lot on how good your case is with acoustics.
