- 24 Aug 2005
- Uranus
Gonna buy an x2 and overclock it to replace my sig cpu, so what cheap x2 is best with an fsb of 250mhz (1:1 with ram)
Zefan said:It depends entirely on budget. I mean, a 3800X2 is likely to be less overclockable than a 4800x2 but IMO it'd be a waste of money.
easyrider said:not true,
a x2 3800 will clock ,
a 4800 will not clock further just because of its stock higher speed
Zefan said:the key word there being LIKELY.
easyrider said:a 4200/4600 is a waste of money as they will clock the same.Only thing is the multi
danoliver1 said:Probably go with the 3800 will order it after conroe gets released maybe it will be even cheaper![]()
Zefan said:So they're exactly the same chips passing exactly the same tests? AFAIknew they all go through testing and they are sorted into which are most stable at certain clock speeds.
easyrider said:just diffent multi's
2.0ghz and 2.4ghz is nothing for these chips
) the 3800 X2 is the one to go for unless you have money to waste. Spending twice as much on a 4400/4600 is unlikely to gain more than 5-10% in real-world performance once they have been overclocked.trojan698 said:It's not about the multis or the higher stock speed, fools. its the manchester vs the toledo core.
and when asking for advise dont roll eyes lol
Just a tip calling people fools in forums that offer information to others is not big and clever and makes you look like one yourself tbh
