Which android IPTV box?
23 May 2004
Hi there,
Which android IPTV box do people recommend?
I would like one that is able to use iPlayer, itv hub and all4 and works very well with a VPN as VPN will always be used. I have read recommendations on Nvidia shield but heard the app store is limited?
Thanks
+1 for Nvidia Shield. Works well for IPTV.
And you can side load the apps. I use Dropbox, upload the app from my phone and download onto the Shield.
