Which antec case is better?
16 Nov 2008
West Midlands
The antec 902 gaming case or the antec 1200?
May be a silly question to ask for my know the antec 902 came out after the antec 1200.
I was planning on getting the 902 but then everybody told me to go for the 1200. They are both identical apart from the 1200 is about 4-5 inches taller I think. And therefore has more drivebays etc. Your choice, if you only have one graphics card go for 902.
The 902 is a midi-tower, the 1200 is a full tower. Personally I would go for the full tower as they are easier to work with.
I've got a 900, and although it fits everything perfectly, It would be useful to have an extra couple of inches at the top to fit the board in easily. Also, I can't fit a hard drive in a bay at the same level as my graphics card, so that isntantly knocks it down to 5.
1200 If you need more space or have 2 cards.
