Which Arctic Cooler?
27 May 2004
UK
Can someone please just clarify which Arctic Cooling Silencer/cooler I need for;
a) an ATi 9800 Pro 128MB
b) An NVIDIA 6800LE
There seems to be some discrepencies between the models for specific cards as shown by Overlockers with those I've found on other on-line PC parts stores & e-bay.
gt_junkie said:
I'd be careful with the one on ebay!
If you look here: http://www.arctic-cooling.com/vga2.php?idx=11
It states this cooler's exclusively for 9800xt's - it probably won't fit your pro!
gt_junkie
Ah ha! Good one. I hadn't seen that. won't go for that one then.
Bit confusing all this - I'm concerned that each cooler seems to be specific to each chipset. Yet it bolts onto the card!! Surely the cards are not a standard size as depicted by each chipset?
Well in the end I bought one for the 9800 Pro ...... The fan didn't work! Turned out the gfx card was shot to bits anyway!
The GForce 6800LE was still under warranty so I RMA'd that & got a replacement.
