Hi all,
I am replacing some professional wiring from the 1990’s:
someone 30 years or so ago did the above for a pond pump.
I was gobsmacked when I saw an extension lead plugged into a double socket running over 30 metres to power a pond pump like this. What were they thinking lol maybe outdoor wiring then was not as good as today?
It is about a 30 metre distance needed to power up a pond pump and possibly some lighting for the pond in future (although I have not had a chance to think too much about this yet)
I am looking to replace the cable as it was just normal cable put inside plastic tubing.
I believe armoured cable is the right cable to use here but but which one should I use? Ie mm? 3 core?
Considering to use a FCU inside the garage to control this pond pump, as opposed to plugging it in like the previously owners did.
- which cable?
- what glands?
- which cleats for the wall
- which outside junction box is sufficient for this project?
Thanks in advance
P.s armoured cable looks solid might need a hacksaw here!
- which cable?
- what glands?
Thanks in advance
