which battery?
ah, ok, sorry i though you'd be able to get it from the back of the adapter!
Laptop is a MSI Megabook M670
model MS-1632
DC rating 19v 3.42A
That's what i am after - a new ac adapter. Why did you think i needed a battery? ;)
(ninja edited as i obvioulsy had a major brain meltdown this morning!)
Basically search for an adaptor with the same voltage rating but a higher current rating (around 4.73A, a 90W adaptor) then you know its never stressed too high.
Just search using the kind of connector and the voltage.
just a warning, the same model number brick can have different kinds of connectors.
