Which beer to cook with?
8 Nov 2008
Gillingham
Now the weather has turned I think it's time for me to get out the slow cooker and make some casseroles, normally I'd make it with water/stock but it was suggested I try using some real ale instead.
So, any suggestions which one to use which gives a nice flavour, or will they pretty much be the same after a few hours on the cooker? Something I could pick up at Tesco etc. would be ideal.
Cheers!
Guinness / Murphy's is the classic (actually cooking a beef & Guinness stew as I type).
You could use any decent ale tho. I would stay away from the hoppier ales tho, as you will probably be left with a little too much bitterness.
I think Kent Ale has made some nice stews. I normally go with 1/2 kilo meat, two carrots, two medium onions, small handful of pearl barley, 500ml beer, one Oxo stock cube. Thicken and season once cooked :)
Any bitter or darker is good. More flavour the better.
Que us all stating are local brewer choice.
Bath dark side or gem for a lighter stew.
Just don't forget the dumplings, god I love dumplings and non of this light fluffy rubbish. Artery clogging, stick to your ribs on the way down ones.
Guiness (Origional not the foamy stuff) is a classic for the simple reason that it works really well.
I've also made some really nice Steak and Ale Pies using a variety of beers my favourite was made with Spitfire.
Strong tasting ales I'd say - Pedegree, Old Thumper work fine.
I wouldn't recommend using Spitfire for cooking. Far better to drink it!
I have a bit of a theory, I won't cook with any wine or beer that I wouldn't drink, not sure if I'm just being a snob or not!
Steak and Spitfire pie served with chips and a bottle of Spitfire is heaven!
But cheap French lager works amazingly in a chilli con carne :)
Your assuming I don't drink cheap french larger ;)
Being slightly more serious never heard of putting larger in a Chilli I've always used red wine do you just do a straight swap? Got a recipe?
