Which Benchmarking S/W?
22 May 2007
I'm after some decent benchmarking software that is capable of throughly benchmarking quad cores (multi-threaded!) along with (or possibly as an additional) memory test L1 - L3 (load, store, prefetch etc.).
Any recommendations?
sisoft sandra is pretty cool for benchmarks, allows you to compare your results with other chips/boards as well.
Sisoft lite looks quite good. I'm using Passmark at the moment but was wondering if there is anything a bit more thorough, and you may have it there!
Thanks mk17!
If its stress-testing you're thinking of, have a go on Orthos, and Prime95 - Azza's linky has everything you'll need. Best of luck mate.
