- 10 Dec 2007
Recently built a GA-P35-DS3P, Q6600, 4GB OCZ 800MHz RAM. The system is basically just not stable no matter what I do. At first I tried some pretty mild overclocks (3GHz @ 333x9, 2.8GHz @ 400x7) and the system would almost immediately freeze when I tried a 'In-place Large FFTs' or 'Blend' torture test on Prime95. The 'Small FFTs' test in comparison seems to be stable up to 3.2GHz (haven't tried it higher than that).
I was advised to give the RAM a going over to make sure that it was OK. So (I apologise for the very poor picture quality, they were taken with a laptop webcam)...
First I tested one 2GB stick in memtest86+:
Wow, 524 errors?? I googled the errors and found that the DS3 boards sometimes give '__feedf18' false positives in memtest.
I test the same RAM in the same rig with Windows Memory Diagnostic:
Lots of errors again, but the same errors.
I take a stick of 1GB RAM from my old machine, which I know to be good, and test it in the DS3P:
Loads of errors, and yet again they are _feedf18 ones. Hmmm.
Just to make doubly sure, I take one of the 2GB OCZ sticks, and test it in my old rig:
That pretty much settles it, then. I guess the RAM is fine and the DS3P is just giving me false positives (at least I assume that's what all the errors are from the RAM tests on the DS3P...?).
Discounting the RAM for now, I played around with the FSB and multi to see if I could find any combination that was actually stable, but it doesn't seem like there is one. I've underclocked the ******* system significantly with no success - I've tested it at 2GHz 333x6 and 2.1GHz 266x8 and it still fails within minutes.
So, to conclude, something is wrong with my system, but what? I'm damn sure I need to RMA something, but I'm not experienced enough with hardware to actually deduce what it is. Can anybody put all of the above together and come up with a plausible answer? If I have left out any information which might be helpful, please let me know.
Thanks,
mg
Thanks,
mg
