Which budget case with filters?
If you can define your budget, I think more responses will be forthcoming. :)
I'm considering the Fractal Arc Midi R2 at the moment as a "budget" alternative to the Corsair 750D. Both appear to have good quality filters.
Good point, DOH.
It is for a second rig.
Budget is as low as possible. It is for a second rig so does not have to be anything flashy or be super efficient at cooling.
I just need good filters and ATX support.
Thanks.
Probably better off getting a cheap case and filtering the intake fans.
Keeping the case with positive air pressure (more air in than out) should help to keep the majority of dust out.
