Which budget polarizing filter for reducing window reflections?
19 May 2005
Lancashire
I am wanting to get hold of a polarizing filter for my camera, but it wont be used much so i don't want to spend a fortune.
I have seen one on Amazon for £8 + delivery that is apparently by Hoya. It has 215 customer reviews and seems to be mostly positive so figured it might be worth a try. Am I allowed to post a link to the product on amazon?
Also not 100% sure if it'll fit or how to find out. My lens is a Nikkor af micro 60mm and the lens cap says LC-62mm. The filter I'm looking at says 'Hoya 62mm Circular Polarizing Screw-in Filter' I take it this will just screw into the thread where the lens cap currently sits?
Camdiox ND filters get pretty good reviews and they do some polarised ones as well
