Which C2D CPU
10 Mar 2007
Essex
Just getting round to do a new build after having the same PC for 3 years its slowly starting to die (RIP).
My main use of this machine will be video encoded and playback, I don't intend to do any gaming, so other uses will be general stuff etc etc
I'm unsure what Core 2 Duo chip to use which would easily suit my needs, the recent price drop makes the E6600 with its 4mb cache around £150 which looks a bargain, but is this overkill for my needs.
Any advice appreciated
Will_3rd said:
Most of the C2D line has been updated to 4mb L2 cache, so the obvious choices are either the 6320 or 6420.
I did look at the 6420 is there much difference performance wise between that and the 6600 ?
not really apart from about 300mhz, but the 6420 can be clocked easily to 6600 speeds and beyond.
Never over clocked before guess I'll need to read up a bit first
