Which Camera? (~£100)
14 Dec 2003
Edinburgh
looking for a camera for my girlfriend's birthday - basically it needs to be small and easy to use. She's likely to use it a lot but doesn't care too much about super-high image quality. Best to find something she can just carry about in her bag whenever she's out.
Budget's around £100 but could probably stretch a bit for the right reasons.
casio exilim (is that right) is about 125 and seems a very good camera, even has image stability, my grandad has one, and he is very happy with it
also the fuji f30 has good reviews, both are abotu the same size and price.
also there is the second hand option on the usual online auction web site
Go for the Fuji definitely, check out the sticky at the top for other information. ISO is more useful in a compact than the IS imo. If she is using it on nights out for example then the image stabilisation will just mean she gets blurred shots whereas with the fuji she will get enough shutter speed (maybe) to make things a bit better.
Excellent battery life and easy to use too...
