Which Camera out of these two?
14 Apr 2003
Deepest Yorkshire
Which out of these two would you think was the better option? Is the 600d a lot better than 550d? It seems to just have the swivly screen, I think the 55-250mm lens might be more useful though
Canon EOS600D Digital SLR Camera + 18-55mm Lens + 55-250MM Lens
£777
Canon EOS550D Digital SLR Camera + 18-55mm + 75-300mm Lens Kit
£642
The only major difference with the 600D is that it has a flip out screen, other then that it uses the same sensor and the image quality against the 550D is more or less identical.
I'd go with the 550D the extra £130ish isn't justified at all for the 600D.
What types of photography are you interested in?
Bit of everything really, holiday photos, landscapes, night shots. I'd quite like another zoom lens in addition to the 18-55 as i'm off to South Africa next month on safari so it will be useful to have a decent telephoto.
I'd go for the 550D and use the spare money towards a telephoto.
Not really a big difference between the 550D/600D apart from a flip out screen and wireless flash control.
how much can you find the 550D with 18 - 55 IS for without the 75 - 300 cos its a terrible lens. as stated above, with the cash you dont spend for the 75 - 300 in that two lens deal you can put towards getting either the 55 - 250 or the 70 - 300 as they are both better zooms for your cash (55 - 250 better value over the 70 - 300 though)
