Which card for 250 max?
  • Thread starter Thread starter Xon
  • Start date Start date
Xon
Xon
18 Oct 2002
Malta
Hi all
I have spent the past week trying to decide on a card and I simply cannot reach a decent conclusion - too many choice out there.
I'm upgrading from an R9 380 - I play some guys but not major. Currently Division 2, Forza 7 and WoW.
Where should I be looking? I've lookd at the below but there are so many versions of them I'm still lost!
- RX 5600 XT
- RX 5700 XT
- 1660 Super OC
- 2060 KO
I'm going to get a Ryzen 3600 - my main monitor is 2560x1440 (60hz) and I also play on a 4k TV - but on the TV I usually set the res to 1080p.
Ok. Well, the 5700XT will be the fastest out of all models listed, though I don't think I've seen them go for £250 - as mentioned in your title. Maybe that was a typing error.
Make sure your PSU is in good shape.
I've not found the 5700XT go for 250 - that was just a list of cards I've looked at. I realise now the post might have been misleading..
I don't know if its worth spending the extra for what I play...
£300+ rx5700xt and RTX 2060 Super
£250 - 300 Rx 5600xt or Rx5700
£200-250 1660 Super (there is a nice 3 fan model for £220 performance like Ti
Hi all
- RX 5600 XT
- RX 5700 XT
- 1660 Super OC
- 2060 KO
5700XT is the fastest of the batch and you can get the XFX THICC III (dont get the II) for £345 these days.
Otherwise 5700 even reference model (don't flash to 5700XT the ref model). You can find these between 280-300.
Bellow that 5600XT.
Used V64 (avoid Strix & reference model), or V56.
FYI you can buy a V64 Red Devil for £180 used these days, one has 4h left under the hammer....
Ofc you need some good PSU....
