which card for 3d vision?
6 Mar 2009
Flintshire North Wales
Hi all.
Looking at getting nvidia 3d vision.
I will playing games in 1680x1050 (which is top res on them monitors)
Now my problem is I can only get 1 Nvidia card on my mobo. Also I dont want to get a 295 as cant justify the price!
Does 3d vision add a load to the Graphics card? or does it work of CPU?
Would a 260 be enough? would like to play these games in order of most played.
1- World or Warcraft
2- Left 4 Dead
3- Race Driver: grid
4- Unreal Tournament 3
5- Elder Scrolls
Would it be worth to upgrade to a 275? or would this be over kill at this resolution? or does 3d vision need the extra power? as cost is extra £40.
285 i have been told to stay clear as not worth cash? this right?
the 260 should be fine, since you already have it just try it out and if it doesn't prove good enough for you, go for the 285 as the 275 is a small upgrade to be honest from a 260.
If its not good enough but you can bear it just wait for DX11 Cards.
Aint you suppose to have the Samsung 120hz monitor to get the best results from the 3D vision which is only supported by a limited amount of games?
