which card for adobe CS5
14 Jan 2010
can someone recommend me a card for CS5 use, preferbly around the performance of an ATI 5770 (in general gaming). CPU will be a i72600
Doing what exactly?
If you're after CUDA acceleration for the Mercury Playback Engine then grab a GTX 460 2GB version (Palit or Gainward) and you're flying. You will need to do the supported card hack (http://www.indiev.org/?p=308) though.
If you're after OpenGL acceleration then pretty much any card from the past year with 1GB RAM will be fine.
Alternatively, you could do things properly and get a Quadro, but you didn't give an indication of budget :p
Whats your budget?
Either Nvidia or ATI is perfect for photoshop you dont need a super duper graphics card.
A GTX460 or an ATI 6850 is fine.
