Which card for my build?
23 Dec 2014
Burgess Hill, West Sussex
Hi,
Having gained plenty of advice on here I am planning the setup below.
I am left with about £150ish in the budget for a GFX card and wondered what would be best? I prefer NVIDIA cards which for the budget means I will be looking at a GTX950/960.
My basket at Overclockers UK:
Total: £574.85
(includes shipping: £0.00)
Get a used 780 or or something like that. Anything less and going to be waste of nice system.
Except you plan to upgrade later on.
I would be a little worried about a second hand card, where would be the best place to buy?
I don't mind upgrading in the future. The plan was to get a motherboard / cpu that I can upgrade and will last a few years.
i suggest 380 159£ or 380X 189£
these gpus are freesync compatible, one of the major gaming features in 2015, so if you are going to buy a monitor along side that build you could go for the AOC 165£ 1080p, 1ms, 144hz freesync, without breaking your bank.
