- 19 May 2009
Hello all, any advice before i go to overclockers later.
Have decided to upgrade my card to match my monitor's resolution (1920 by 1200). I think i am going to get an ATI HD 4870 X2. Should i go for two 4890's instead? Or should i go for an nvidia card bearing in mind i have an intel chipset so wouldn't be able to sli...
hmmm..
If i end up going for the 4870X2 ... should i buy one of these (heard this is a lot quieter which attracts me towards it)
http://www.overclockers.co.uk/showproduct.php?prodid=GX-083-GW
or should i get the cheapest one,
http://www.overclockers.co.uk/showproduct.php?prodid=GX-118-XF&groupid=701&catid=56&subcat=1235
and get two ... i have a budget of 500ish for upgrades so any advice, cheers in advance.
P.s.
System spec:
Qx9770
foxconn blackops
4GB ddr3 1800mhz
GPU?
Enermax 1000W galaxy
Would like to get another hard drive, but this can wait if its worth crossfiring two x2's.
EDIT: Does the 4890's 1000Mhz mean that perhaps i should even be looking at crossfiring two 4890's??? ...
hmmm..
P.s.
System spec:
Qx9770
foxconn blackops
4GB ddr3 1800mhz
GPU?
