which card thanks
3 Aug 2013
hi i brought a his 7850 4gb graphics card after returning a failing r9 280x i have one question the 7850 4gb is a big card so is a tight squeeze in my case will i get a performance increase if i took it back and changed it to a Sapphire Radeon R9 270X Boost OC 2048MB or do you guys know a nvidia gpu at £150 which will beat both these cards i plan on crossfiring in the future thanks
I'm a little confused, you returned a failing 280x and replaced it with a 7850 ??, why didnt you just replace it with another 280x ?, personally i'd rather a 280x than a 7850 crossfire or not. An no you wont get an nvidia card for the same price with comparable performance unless you're buying second hand.
basically they had no r280x in stock so i thought get a 7850 4gb and crossfire it but its a tight squeeze in my system so my question is will a r9 270x be a better option as its same price and i can crossfire them i plan on getting a good 780 in members market once i get enough posts and time here thanks
