Hi all, I've decided on a i5 3570K with 8GB build but I don't know which card to go for. The 7950 is out of my price budget which is £150, and I have found instead the following on the Clearance section:
YOUR BASKET
1 x **B Grade** KFA2 GeForce GTX 660TI EX OC 2048MB GDDR5 PCI-Express Graphics Card £149.99
1 x **B Grade** Sapphire HD 7870 XT rev2.0 2048MB GDDR5 PCI-Express Graphics Card with Tomb Raider & Bioshock PC Games £149.99
1 x **B Grade** Gigabyte GeForce GTX 570 SOC WINDFORCE 3X 1280MB GDDR5 PCI-Express G (GX-085-GI) £119.99
1 x **B Grade** MSI HD 6970 OC Lightning 2048MB GDDR5 PCI-Express Graphics Card with FREE Deu (GX-141-MS) £119.99
1 x **B Grade** MSI HD 7850 OC 2048MB GDDR5 PCI-Express Graphics Cards with Tomb Raider & Biosh (GX-191-MS) £119.99
If it helps, I play MMORPGs at 1920x1080 maxed and I have both a XFX 550W and Corsair 500W power supply.
Which should I pick? Regards.
YOUR BASKET
and will be enough to max out nearly every game at 1080p 60fps.
