Which Card ?
4 Aug 2007
Hello everybody, just wanted to ask, which product should i buy for the best possible GAMING experience, budget isnt really a problem, im not so sure i need fancy extra features. I just want the best possible gaming card and all i need in addition is a microphone jack. Any suggestions? After browsing the creative website I was thinking either the X-Fi Platinum Fatal1ty Champion Series or the X-Fi XtremeGamer Fatal1ty Pro Series. I currently have an X-Fi XtremeMusic. Thanks very much for your help.
Does that include headphones/speakers/joysticks etc?
That's about as good as it gets right now. As far as I know the only thing your current card is missing is X-ram which according to several reviews I have read doesn't really make a lot of difference?
I am only interested in sound cards. Well what about other manufactorers such as Auzentech. Im sure there is something on the market that wipes the floor with an X-Fi XtremeMusic, considering its the bottom line of the X-Fi range...Thx.
AFAIK, the higher up cards in the X-Fi range are specced pretty much the same as low cards, save for less connectivity options like a breakout box and external boxes.
So you mean the top end of the X-Fi range are very similiar to the lower end of the Auzentech line ? can anybody confirm this? Thanks!
