Which Card?
20 Jan 2011
My motherboard is a P5N-E SLI. What is one of the better cards I can get for under £100 for this? A lot of the cheaper ones I can find are either discontiued or have terrible reviews.
Any help would be much appreciated.
Looks good to me. Is the 1gb version of the 460 GTX worth the extra £20 ish on top of the 768MB?
If you can find a 1 Gb 460 for around £150, its definitely worth paying that much for. The MSI Cyclone or Asus Direct CU are very reccomendable models, the MSI is on offer this week for £155.
However, if you are willing to wait, I'd suggest pre ordering the MSI 5850 for £129.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-103-MS&groupid=701&catid=56&subcat=411
Was more than I wanted to pay, but like they say, if you buy cheap, you buy twice.
Should be on its way soon (The 5850). Many thanks.
