which card
14 Oct 2007
newcastle
which card should i get to go with my res im using a 720p 32" tv as my monitor ATM im using a gtx260 but am going to have some spair money at the end of this month so which card should i go for?
If I was in the market for a card, I would get the SOC 480, but at £230, its slightly over your budget, but would complement the rest of your system.
Otherwise, I think your looking at a 6950
I can't imagine a GTX 260 is struggling too much at 720P to be honest. The only downside is it isn't DX11. I'd recommend upgrading to a higher res monitor/tv before considering your video card options. A GTX 480 or 6950 is way overkill for the res.
