WHICH CARD?
1 Jun 2012
im just about to build another pc
an i5 Haswell
which card should i go for?
Asus HD 7970 Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card (2 of these)
or
Asus HD 7990 6144MB GDDR5 PCI-Express Graphics Card
Which would be best?
Most of the time, you'll be fine with more than one graphics processor if you're running an i5, though there are a very few games that will benefit from the hyper-threading that an i7 has.
If I was buying right now, I'd consider something like this :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-293-AS&groupid=701&catid=56&subcat=938
http://www.overclockers.co.uk/showproduct.php?prodid=GX-225-MS&groupid=701&catid=56&subcat=1842
http://www.overclockers.co.uk/showproduct.php?prodid=GX-032-IN&groupid=701&catid=1914&subcat=1750
If you're after something even more powerful then the 7990 is a good shout providing it's at a decent price, or some of the reduced 780s.
