Which card?
11 Sep 2008
Co. Durham
Hi All
Will pulling the trigger on a GTX 780 today but im so out of the loop need some help. Talking about the rig in my sig and to replace the 6970.
Now i like the
KFA2 GeForce GTX 780 3072MB http://www.overclockers.co.uk/showproduct.php?prodid=GX-044-KF&groupid=701&catid=1914&subcat=1341
or
Asus GeForce GTX 780 Direct CU II 3072MB http://www.overclockers.co.uk/showproduct.php?prodid=GX-349-AS&groupid=701&catid=1914&subcat=1341
the £30 make no difference but i dont want to go a penny over £230. I wont be OC any card im looking for the one with less noise reviews just say their both super quite. Also my case lets the card exhaust from the top so blower whould be better for temp or will the asus still be better at cooling the card but assume it will raise case temps and it does not exhaust if that make sence?
I assumed only the 1st 12 months of the 3 years warranty for the asus is with ocuk and the ka has 2 years but ocuk handle
the possible rma for 2 years?
According to the warranty thread, they handle the full 3 years, OCUK will chase Asus if they take longer than 28 days to get your replacement.
Ah nice one very helpfull but now that make me ponder even more, what puts me off the asus is the heat remains in the case where the ka exhausts, I guess the asus should be quiter of the two?
I would say for sure the Asus would be the quieter and cooler. As you say your case exhausts the card from the top so wont be much of a problem.
Thanks all defo wont go dual gpu did that in my younger more foolish days for me :P
As ocuk help if there a problem the asus will match the rampage i guess :)
