I'm after a new case to replace my aging and extremely nasty old thing that's currently in use.
My current case has fans all over it, and it's quite noisy.
Idealy I want something with less fans (i.e a couple of 120mm fans instead of loads of 80mm fans).
Also, I would love something that has provision for a bit of sound proofing and also intergrated drive damping of some description as one of my drives is pulsing, and I've just got a Spinpoint F1 to install, which isn't the quietest drive in the world.
So far I've found:
Cooler Master CM690 - I like the look and features of this one, is it any good?
Thermaltake Soprano - Not so sure on this one, a bit form over function maybe? Probably rubbish for soundproofing with the side window though.
Aero Cool S9 Pro - No chance of soundproofing, but has a mahoosive 400mm side panel fan and rubber HDD mounting grommets. Probably sounds like a helicopter though....
Are there any others that are better suited to silent operation in budget, or that are just well, better?
Before I forget (not that this will likely be an issue) - the case needs to take an 8800GT with Acellero S1 fitted.
Cheers
So far I've found:
Cheers
