- 29 Aug 2010
- Cornwall
OK, so I've just fitted (assuming the leak test goes ok) custom WC loop with a 240mm rad in the top of my Corsair 540 AIR.
Now my concern is that I have the 2 stock 140mm intake fans but now have a 140mm exhaust and the 2 120mm rad fans (Apache Vipers) also exhausting. This is likely to give me negative air pressure in the case. I'd like to try to remedy this if I can, at least to some degree.
So my plan is to replace the 2 stock 140mm fans with 3 120mm fans.
So I'm wondering what's my best bet for quiet 120mm fans that shift a decent amount of air to help balance out my case air pressure?
The other thing is, it'd help if they had really long (over 31cm) cables as I plan to power them off the motherboard headers along the bottom of the Gigabyte Z87X-OC board (due to the 540 not being ideal for fan controllers).
I could probably use a fan splitter or 2 to drive all the fans off 1 header while also negating the cable length issue. I'm just not sure what current each of the fan headers can supply, does anyone know?
