Which case fir AM2 Rig
1 Dec 2005
Stoke on Trent
Which case will be better, got 3 options :
1. Thermaltake VB1000SWS Soprano SuperMidi Tower and a 430W Tagan Modular
2. Lian Li PC7 Plus and a 430W Tagan modular
3. Antec Sonata II Piano Black Quiet Case - 450W
Which is the better combo and what will provide better cooling? Am i right in thinking they all have 120mm rear fan?Will any be physically big enough to fit an X1800/1900XTX in. Fits in my lanboy but its a squeeze
Cheers, does the pc7 that ocuk stock deffo come with 120mm fans front and rear, as ive been looking at review and some do and some dont :confused:
All since around september that I know about have been a 120mm / 120mm one.
PC7+II or PC007 which has blue stock fans, thats the two that seem to be shipped. They all use the same box though, why the spec can never be guaranteed, but you do have the distance selling act on your side.
Not hard to mod aswell, but I would be amazed if OcUK had a batch of the 80mm ones in due to them for almost a year as far as I know just shipping the updated version. :)
