Hi, I'm currently waiting on a 5090 preorder thats due soon. I have been looking at moving my current base system to a new case with a new psu for the 5090 upgrade. I currently run a worn out phanteks enthoo case but I have been looking at some cases to replace it. The first case I decided on for the separate PSU chamber and airflow and gpu display is the Phanteks NV7 D-RGB with 8 m25 phanteks fans and the other top mount fans filled with my 240 aio. I would use 3 reverse m25 phantek fans on the bottom to pull air upwards and the other fans pushing out. Upon researching the fans they seem complex to install and the real solution d50 fans would cost more than i can justify for fans.
The second case im thinking of getting is the Be Quiet! Light Base 900 FX with just the stock 140 fans installed this seems more practical as I'm a pc enthusiast but also a very tired works 7 days a week a lot person who wants a easy setup.
What do you think is the phanteks with the m25 fans good or is it only good with 300 quid of fancy fans?
My current specs that will be moving into the case minus GPU and PSU is:
7900x cpu, 32gb 6400mhz ddr5, arctic freezer 2 240mm aio, 3080ti.
