Which case for cheap pc build???
5 Dec 2005
Here is my build, just wondering if i should go for that case, or if i can get away with getting a cheaper one. i dont really want to skimp on the psu but if i wont notice any difference in performance or stablility then im happy to spend lesss....
any help would be great
cheers
Duncan
Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard (MB-004-AK)
£44.95 £44.95
CP-116-IN Intel Pentium 4 805 Dual Core "LGA775 Smithfield" 2.66GHz (533FSB) - Retail (CP-116-IN)
£59.95 £59.95
HD-024-SA Samsung SpinPoint P HD160JJ 160GB SATA-II 8MB Cache - OEM (HD-024-SA)
£34.95 £34.95
MY-030-GL GeIL 1GB (2x512MB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX21GB5300DC) (MY-030-GL)
£51.95 £51.95
CD-056-LO Liteon SHW-16H5S-15C 16x Lightscribe DVD±RW - Retail (CD-056-LO)
£21.95 £21.95
CA-048-AN Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU (CA-048-AN)
£54.95 £54.95
UP-005-BE Belkin 4-Socket SurgeMaster (F9H400UK2M) (UP-005-BE)
£5.75 £5.75
Subtotal £274.45
VAT £48.03
Total £322.48
Was there a real need to bump after 1 hour, not like it was 3 pages deep and days old?
Everything looks fine there, would not dare go any cheaper on the PSU and bar an AC T2 case and bundled Seasonic PSU there are not many more options open to you.
