- 8 Oct 2008
I'm looking for a case that will support a dual cpu motherboard such as http://www.overclockers.co.uk/showproduct.php?prodid=BG-730-AS
Although a fair few cases listed on the site do support the EEB Form Factor
12 inch x 13 inch ( 30.5 cm x 33.02 cm )
I'm struggling to figure out which case has space on the motherboard tray to support dual cpu's, as it looks as if they only have the cut-away for 1 cpu.
I currently have a coolermaster storm, which is huge, however doesn't appear to be huge enough, from reading specs.. - I wouldn't be upset if I could keep using it.
Any ideas or suggestions.
